Home | Reviews
Login  |  Register
Interbike 2006
Track Hub
Fixed gear simplicity and function for the track or the street at only 180 grams. Full diameter clamp bolts combined with a large 21mm drive side contact point insures this hub will not pull under heavy load. The large 17mm axle is stiff and helps align the precision fully sealed stainless steel cartridge bearings.
  • Discipline: track or road
  • Bearings: 6803 C3 sealed stainless steel
  • Drilling: 32 hole, lock ring included
  • Spacing: 120mm
  • Color: black
  • Spoke Circle Diameter: 66mm
  • *C-T-O Left Flange: 37.20mm
  • *C-T-O Right Flange: 32.70mm
  • Bolt-On: steel bolts included
  • Weight: 180 grams
    (*Center To Outside)
    Options: ceramic bearings
  • << Previous Next >>
    Back to the American Classic booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
