Home | Reviews
Login  |  Register
Interbike 2006
Trigger (frame)
TRIGGER
The Trigger is a purpose built extreme freeride frame for those who live for the big. With rear travel settings for 190 mm (7.5 inches) or 216 mm (8.5 inches) you can tame the most hostile territory and tackle any terrain. With a front derailleur coupled with the amazing pedal-ability of the Trigger suspension, shuttling can still be optional. The 12 mm x 150 mm rear dropout spacing and ONEPOINTFIVE standard head tube gives you that extra edge of confidence while rippin’ down your favorite chute or pinning that death defying gap.
Hold the Trigger in your fingers, and you could swear that it was machined and honed out of one block of aluminum in Switzerland. This quality level and attention to detail is where we will never compromise. Every detail of this frame was designed to provide you with the ultimate frame for FRX indulgence.
  • Needle bearings at all pivots with external grease ports
  • Laterally stiff rear suspension
  • Full custom CNC machined rear suspension components
  • ISCG-05 standard chain guide mount, 73mm BB, front derailleur capable
  • Gusseted, “ONEPOINTFIVE” standard head tube, dual crown capable
  • Two travel settings: 190mm (7.5 inches) or 216mm (8.5 inches).
  • Colors: Matte Gunmetal Grey or RAW
  • Sizes: S, M, L, XL
  • Shock: Manitou SW 4-Way (standard), Fox DHX 5.0 or Marzocchi Roco (optional)
  • Next >>
    Back to the Versus Cycles booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2009 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
