Click Here for Coverage of Interbike 2008!
Home | Reviews
Login  |  Register
Interbike 2006
Black Diamond Triple
FRAME: New Mongoose Freedrive Extreme 6061 Aluminum w/ Patented Floating BB, 1.5” Headtube, Replaceable 150x12mm Maxle Dropouts & Disc Mount, Adjustable 6.5/7.5” Travel
FORK/SHOCK: Marzocchi 66SL 1 ATA w/ Dual Air Spring, 140-180mm Adjustable Travel, RC2 Rebound & Compression Adjust, 20mm Thru Axle; Fox DHX Air-4.0 Air Spring w/ Piggyback Reservoir, Boost Valve, Adjustable ProPedal Damping, Adjustable Tuning Range, Preload & Rebound Adjust
DRIVETRAIN: SRAM X-9 9-Speed Derailleur, SRAM X-9 Trigger Shifter w/ Matchmount; FSA Gravity 36t Crankset w/ Bashguard & External Bearings
BRAKES: Avid Juicy 7 Hydraulic Disc w/ 203mm Rotors
WHEELS: WTB Laser Disc FR Rims w/ WTB Laser Disc Super Duty 32h Thru Axle Disc Hubs, Kenda Nevegal FR 2.5” Tires w/ Stick-E Rubber & Pinch Flat Protection
COCKPIT: Easton EA70 31.8mm Bar & Havoc Stem, Titec Knockscoper I-Beam Telescoping Post & SDG Bel Air ST Saddle
MSRP $2899
<< Previous Next >>
Back to the Mongoose booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
