Home | Reviews
Login  |  Register
Interbike 2006
6POINT8
6POINT8 / AGRESSIVE ALL MOUNTAIN
With incredible efficiency and practically endless traction, the all-new dw-link 6point will push you to conquer the most rock-strewn and technical climbs in existence, then let you open it up on the way down. The lightweight 7.3 lb. frame is crafted using our o.p.t. tubing and 6069 T6 material to provide a stiff, strong, and responsive ride. The 6point also features our new 10-mil shock pivot standard, and oversized o-pivot assemblies with our exclusive max-e bearings for low maintenance and longevity. mounting a chainguide is simple with iscg05 standard mounts integrated. coupled with a 150mm travel fork, a fox dhx air rear shock complements 6.3 inches (160mm) of efficient and compliant dw-link travel to round out this trail eating package. you need to ride the 6point to understand how good it really is.
TECHNOLOGIES: dw-link, o.p.t., 10-mil, f7, max-e, 6069, o-pivots
FRAME 6" TRAVEL DW-LINK ALL-MOUNTAIN FRAME, 1.5 HEADTUBE, 150MM X 12MM THRU AXLE HUB, 83MM BB SHELL, REPLACEABLE DERAILLEUR HANGER
REAR SHOCK FOX DHX AIR 5.0, 8.75" X 2.5"
FORK FOX 36 TALAS RC2, 150MM TRAVEL
Next >>
Back to the Iron Horse booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
