Click Here for Coverage of Interbike 2008!
Home | Reviews
Login  |  Register
Interbike 2006
iT1
  • Exclusive Formed 6061 iT1 Design Frame w/ Internal Transmission, Revised Geometry, 9” Travel, CNC Machined Pivot Links & Components, 12mm Maxle Thru Axle Dropouts, Stainless Steel Hardware & Sealed Bearing Pivots
  • Marzocchi 888 SL ATA Dual Crown Fork w/ Air Spring, 35mm Stanchions, RC2 Adjustable Travel, Adjustable Compression & Rebound Damping, 20mm Thru-Axle Dropouts, 170-203mm Adjustable Travel; Marzocchi ROCO RC World Cup Coilover Shock w/ Adjustable HSCV Rebound & Compression Damping, Bottom Resistance, External Rebound and Spring Preload
  • Proprietary Shimano 8-spd Drivetrain Mounted Centrally In Frame, RapidFire Plus Trigger Shifter; Shimano Saint 2-pc Crankset w/ External BB Bearings
  • Avid Code Hydraulic Disc Brakes with 203mm Rotors; Crank Bros 50/50 Platform Pedals
  • Sun MTX Freeride Rims w/ 20mm Thru Axle Front Hub & GT iT1 12mm Thru-Axle Cassette Rear Disc Hub; Easton EA70 Monkey Bar Handlebar & Marzocchi Integrated Stem; SDG I-Beam Post & Bel Air ST I-Beam Saddle; Kenda Nevegal 2.5” Tires w/ DH Casing & Stick-E Rubber
  • MSRP: $4999
  • << Previous Next >>
    Back to the GT booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
