Home | Reviews
Login  |  Register
Interbike 2006
K-Force Light MTB Crankset
K-Force Light Compact crankset is the 3rd generation of carbon cranks. K-Force Light Arms are molded using a removable bladder process, which allows maximum compaction of the carbon material, and lowest possible void areas.
This means high strength, minimum material, and best overall performance.
The K-Force Light crankset uses a completely hollow arm design, with an internal I-beam that for high torsional rigidity and lateral strength with reduced weight. FSA’s hollow carbon arm design is unique in the market, and is patented.
FSA’s K-Force Light is a truly monocoque design. The minimal aluminum components (Spindle spline and pedal insert) are laid directly into the carbon material, as an integrated component (as opposed to bonding) for the highest strength and minimum weight.
Next >>
Back to the FSA booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
