40
With a full 8-inches of travel, separate externally adjustable high and low speed compression damping circuits in our patent pending closed RC2 fit cartridge,a titanium coil spring, massive 40 mm stanchions, and yet a truly
remarkable sub-7 lb weight, our 40® is the definitive light-heavyweight champion of the world. We’ve sweated every detail – a tight steering radius, low axle-to-crown height, and our integrated disc brake guide. No other DH fork comes close to offering this level of performance, range of adjustability, and combination of strength and low weight.
________________
RC2 Model
Weight:
6.88 lbs (3.12 kg)
External Adjustments:
> Low speed compression
> High speed compression
> Coil spring preload
> Rebound
Internal Adjustments:
> Travel is internally adjustable down to 6 inches in half inch increments
> Hydraulic bottom-out damper
Travel:
8 inches (203 mm)
Lower Leg:
Disc Only
Spring:
Titanium Spring
________________
R Model
Weight:
6.81 lbs (3.09 kg)
> Coil spring preload
> Rebound
Travel:
8 inches (203 mm)
Lower Leg:
Disc Only
Spring:
Titanium Spring
