32 F-SERIES (X MODEL)
Every other lockout needs some sort of rider-activation. Our patented TerraLogic® terrain sensitive inertia valve technology with our BrassMass™ does it for you. The fully automatic lockout keeps the fork rigid when the terrain is smooth, even when sprinting, yet opens up to allow the fork to become fully active, instantaneously, when the going gets rough. This unique feature, combined with FOX’s industry leading stiffness to weight ratio as well as the most sophisticated and adjustable damping on the market, leaves the FX forks as the racer’s (Terra)logical first choice.
32 F-SERIES (RLC, RL and R MODEL)
This is the speed of light. We pulled out all the stops to create the lightest forks in our line, the 32 F Series. They’re purpose built race weapons with an all-new chassis; for even greater stiffness and improved strength. Our F-Series want nothing more than to see you standing atop podiums. In spite of their ultra lightweight nature, they sacrifice none of the 32 mm stanchion enhanced steering precision and highly evolved and patented damping performance that is synonymous with the FOX name.
________________
X Model
Weight:
F 80 3.43 lbs (1.56 kg)
F 100 3.49 lbs (1.58 kg)
Adjustments:
> TerraLogic
> Air spring pressure
> Rebound
Travel:
F 80 3.1 inches (80 mm)
F 100 3.9 inches (100 mm)
Lower Leg:
Disc Only or Standard
Spring:
Air
________________
RLC Model
Weight:
F 80 3.42 lbs (1.55 kg)
Adjustments:
> Low speed compression
> Lever actuated lockout
> Lockout force adjust
> Air spring pressure
> Rebound
Travel:
Lower Leg:
Spring:
Air
________________
RL Model (OE ONLY)
Weight:
F 100 3.48 lbs (1.58 kg)
Adjustments:
> Air spring pressure
> Rebound
Travel:
Lower Leg:
Spring:
Air
________________
R Model (OE ONLY)
Weight:
F 80 3.44 lbs (1.56 kg)
F 100 3.52 lbs (1.60 kg)
Adjustments:
> Air spring pressure
> Rebound
Travel:
Lower Leg:
Spring:
Air
