Home | Reviews
Login  |  Register
Interbike 2006
32 TALAS
32 TALAS
However you ride, and however you want your bike to handle, 32 TALAS® has you covered. Our proven TALAS (Travel Adjust Linear Air Spring) concept has evolved into a quick three-stage system, adjustable with a 90 degree sweep of a lever, setting travel between 140-120 and 100mm (130-110 and 90mm for X forks.) For 2007 we added an extra 10 mm of travel to meet the needs of today’s trail bike. Combined with our legendary steering precision and all new chassis, and either our new patent pending TerraLogic damping or our ultra-refined and patented RLC open bath system, the lightweight and feature packed TALAS is a sure bet for any trail condition.
________________
X Model
Weight:
3.97 lbs (1.80 kg)
Adjustments:
> TerraLogic
> Travel
> Air spring pressure
> Rebound
Travel:
5.1 inches (130 mm) 130+110+90 mm
(TALAS 3 position knob (90o sweep) travel settings for all 32 TALAS models.)
Lower Leg:
Disc Only
Spring:
Air
________________
RLC Model
Weight:
3.99 lbs (1.81 kg)
Adjustments:
> Low speed compression
> Lever actuated lockout
> Lockout force adjust
> Travel
> Air spring pressure
> Rebound
Travel:
5.5 inches (140 mm) 140+120+100 mm
Lower Leg:
Disc Only
Spring:
Air
________________
RL Model (OE ONLY)
Weight:
3.98 lbs (1.81 kg)
Adjustments:
> Travel
> Air spring pressure
> Rebound
Travel:
Lower Leg:
Disc Only
Spring:
Air
________________
R Model
Weight:
4.01 lbs (1.82 kg)
Adjustments:
> Travel
> Air spring pressure
> Rebound
Travel:
Lower Leg:
Disc Only
Spring:
Air
<< Previous Next >>
Back to the Fox Racing Shox booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
