32 VANILLA
The 32 VANILLA® might just be the unsung hero of the suspension fork world. At just 4 pounds, it is the lightest coil sprung, 5.5 Inch fork on the market. And, thanks to that coil spring and our ultra-refined and patented (RLC) open bath damping system, it is also one of the plushest forks money can buy. For 2007 we redesigned the chassis and added 10 mm of travel to make it longer, stronger and stiffer, watch out Steve Austin. There comes a time when you just want to throw marketing jargon out the window and ride. That’s when the Vanilla - good old, straight steering, true tracking, velvet smooth Vanilla – shines like a diamond.
RLC Model
Weight:
4.17 lbs (1.89 kg)
Adjustments:
> Low speed compression
> Lever actuated lockout
> Lockout force adjust
> Coil spring preload
> Rebound
Travel:
5.5 inches (140 mm)
Lower Leg:
Disc Only
Spring:
Coil
________________
RL Model (OE ONLY)
Weight:
4.16 lbs (1.89 kg)
Adjustments:
> Coil spring preload
> Rebound
Travel:
5.5 inches (140 mm)
Lower Leg:
Disc Only
Spring:
Coil
________________
R Model
Weight:
4.19 lbs (1.90 kg)
Adjustments:
> Coil spring preload
> Rebound
Travel:
5.5 inches (140 mm)
Lower Leg:
Disc Only
Spring:
Coil
