Click Here for Coverage of Interbike 2008!
Home | Reviews
Login  |  Register
Interbike 2006
Curnutt ITD
A simpler and easier to adjust user friendly version of the awesome XTD shock, the ITD is built with the same care as each Curnutt shock. The ITD is for the rider who wants to set it and forget it. With air pressure and rebound control, the bottom-out feature is pre-set from the factory so you just set your air pressure based on your weight and go riding. Available with Ti or Steel Springs the Curnutt does have a rider weight limit of around 230lb with gear, depending on model.
FEATURES:
  • STABLE PLATFORM DESIGN
  • EXTERNAL BOTTOMING CONTROL
  • REBOUND FULLY ADJUSTABLE
  • TI SPRING OPTIONAL
  • ALL ALUMINUM PARTS ARE HARD ANODIZED
  • SECONDARY AIR CHAMBER FOR BIG HITS
  • BUILT TO EACH RIDER’S SPECIFICATIONS
  • 100% MACHINED AND ASSEMBLED IN THE U.S.A.
  • << Previous
    Back to the Foes booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
