Home | Reviews
Login  |  Register
Interbike 2006
4X
2:1 4X – 4X / Dual Slalom
The 2:1 4X is equipped with Foes’ new Curnutt AIR 2:1 suspension, giving the frame a perfect 4” of rear wheel travel. Superb for racing 4X, DS, or your local dirt jumps, the 2:1 4x frame includes heavy duty gussets at the head tube and a one-piece monocoque top tube with built-in contours to arrest torsional twist and yaw. With the 2:1 Curnutt AIR shock and its adjustable rod end, you’ll be able to change the head angle by +/- 1° and raise or lower the bottom bracket height for an advantage when the courses change during the summer race series. Lighter weight, the 2:1 4X AIR has all the qualities to win. Ride a Foes and you’ll be riding the frames everyone knows as ‘the Champions’ Choice’ – hand-built and tested in the good ‘ol U.S.A.
FEATURES:
  • 2:1 LEVERAGE RATIO
  • EXCLUSIVE CURNUTT AIR SHOCK
  • ADJUSTABLE HEAD ANGLE, BOTTOM BRACKET
  • SINGLE PIVOT DESIGN FOR MAXIMUM STIFFNESS
  • FULL COMPLEMENT PIVOT BEARINGS
  • FOES SWING LINK
  • MONOCOQUE FRAME HYDROFORMED AT FOES FACTORY
  • EASTON DOUBLE-BUTTED DOWN TUBE
  • << Previous Next >>
    Back to the Foes booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
