Click Here for Coverage of Interbike 2008!
Home | Reviews
Login  |  Register
Interbike 2006
DHS Mono 2:1
2:1 DHS Mono - Downhill
The 2:1 DHS Mono is an aggressive design that will change the way you think about downhill bikes. It’s equipped with the 2:1 Curnutt XTD suspension, built completely by hand, and features our signature monocoque construction. The 2:1 DHS, endowed with 10” of XTD travel, will provide stability, agility and control you never expected from a downhill bike. Connect yourself with state-of-the-art construction, floating brake control, and intuitive suspension design for a ride that is setting the performance standard in downhill bikes.
FEATURES:
  • 2:1 LEVERAGE RATIO
  • SHOCK SHAFT SPEED INCREASED FO BETTER PERFORMANCE
  • LIGHTER SPRING – LESS STRESS ON FRAME
  • MONOCOQUE FRAME HYDROFORMED AT FOES FACTORY
  • INTEGRATED CHAIN DEVICE
  • 83MM SHELL, 160MM HUB – PERFECT CHAIN LINE
  • FLOATING REAR BRAKE
  • SINGLE PIVOT DESIGN – NO FLEX
  • FULL COMPLEMENT PIVOT BEARINGS
  • VERY LOW CENTER OF GRAVITY
  • ADJUSTABLE HEAD ANGLE
  • EXCLUSIVE CURNUTT SHOCK
  • ADJUSTABLE PLATFORM AND BOTTOMING CONTROL
  • 160MM HUB AND CHAIN DEVICE - STANDARD EQUIPMENT
  • 10” OF REAR WHEEL TRAVEL
  • << Previous Next >>
    Back to the Foes booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
