Click Here for Coverage of Interbike 2008!
Home | Reviews
Login  |  Register
Interbike 2006
Fluid 120
Using a more traditional gas-charged oil damper system, the Fluid Series of forks feature reinforced crowns, steerer tubes, and dropouts for heavier duty trail or park riding.
  • Model Name: Fluid 120
  • Dropout: 20mm Thru-axle
  • Brake mount: Disc only
  • Travel: 100/120mm (3.9"/4.7") select
  • Wheel Size: 26"
  • Damping: Gas Charged Oil
  • Adjustments (external and/or internal): Rebound, Compression, Preload
  • Spring: Coil
  • Stanchions: 32mm
  • Crown: beefy single
  • Weight: 4.7lbs
  • Color(s): Black
  • << Previous Next >>
    Back to the White Brothers - MRP booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
