Click Here for Coverage of Interbike 2008!
Home | Reviews
Login  |  Register
Interbike 2006
Groove Race
Whether speed is your passion or you want to find a line where no one will follow, White Brothers has a downhill fork that will keep you in the Groove. The Groove Race's radical brace, extended overlap bushing system and stiff leading axel, create a 5.5 pound, 180mm travel fork designed for racers looking for speed without losing control. Finely tuned, hand-crafted, fully adjustable proprietary damping and spring systems enclosed in the highest quality legs money can buy-this sums up the White Brothers Groove line.
  • Model Name: Groove Race
  • Dropout: 20mm Thru-axle
  • Brake mount: Disc only
  • Travel: 180mm/7.1"
  • Wheel Size: 26"
  • Damping: Gas Charged Oil
  • Adjustments (external and/or internal): Rebound, Compression, Infinite Air Preload with Self Regulating Negative Spring
  • Spring: Air/Air
  • Stanchions: 32mm
  • Crown: dual
  • Weight: 5.5lbs
  • Color(s): Black
  • << Previous Next >>
    Back to the White Brothers - MRP booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
