Click Here for Coverage of Interbike 2008!
Home | Reviews
Login  |  Register
Interbike 2007
Code Master Cylinder
Code Facts
Intended use: All Mountain, Freeride, Downhill
FINISH: New galvanized body/caliper, black lever
UNIQUE TO CODE: Center-Mount Pad Contact-Point Adjustment, Three cartridge bearing lever pivot, Two-piece lever with cam breakaway, Up-front access reach adjustment, New aluminum cam and other improved hardware
Special features: New magnesium lever body, Four piston caliper, Anchored brake pads, Tri-Align™ Caliper Positioning System™, Power Reserve Geometry™, Center-mount adjustable banjo, Ambidextrous, Split Clamp/Matchmaker™ compatible, Drip-free bleeding
Rotor sizes: 160, 185, 203mm
FLUID: DOT 4
Weight: 449g (160mm rotor; front post mount)
<< Previous Next >>
Back to the Avid booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
