Home | Reviews
Login  |  Register
Interbike 2007
EVO
CHUMBA EVO
Form follows function. We've seen the evolution of mountain bike suspension designs, and we've realized its time to bring something new to the market. Using the patent pending force channeling suspension design, we bring you a bike that inspires downhill racing confidence on your descent, while keeping the chassis light enough to be built as an all-day bike. We'd like to mention, the EVO will gladly take the most serious abuse you can muster and will take your riding to more extreme and higher levels.
Welcome the next chapter of evolution in mountain bike design, the CHUMBA EVO.
Product Features
-Force Channeling Centralization Suspension Design:
(1) Balance point in middle of bike for best handling
(2) Static pivot point moved furthest from your body contact points (the saddle & grips) - reducing suspension-induced vibrations
(3) shock mounted on oversized down tube with beefy shock mounts
(4) lower center of mass
  • Wider diameter Enduro bearings for exceptional reliability and durability E-type derailleur insert to allow use of wider diameter tubing for a stronger and stiffer front triangle.
  • Dual Bearings
  • Beefy Rockers, on average over 20 percent wider than our competitors
  • Over 14 CNC machined parts made at CHUMBA's factory in Anaheim
  • Open Gussets, so stress impact is more evenly distributed
  • Integrated Stiffening Rib, the rib reinforces the compression yoke and adds torsional rigidity
  • Inverted Extra Wide Bottom Bracket Shell, for increased strength and rigidity of the rear triangle.
  • << Previous Next >>
    Back to the Chumba Racing booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
