Home | Reviews
Login  |  Register
Interbike 2007
P.O.V.1 Lens Mount (Rear View)
Mounts Available:
UNIVERSAL MOUNT
DIGITAL POV.1 and ANALOG - This flexible rubber sleeve keeps your cam tight while the hook and loop backing secures the mount to the helmet surface.
DBL HOOK-LOOP MT
DIGITAL POV.1 and ANALOG - This hassle-free mount easily secures the helmet cam to most vented helmets using a hook and loop fastening system. Also good for creative mounting on bikes, autos and recreational vehicles.
RT ANG H-L MOUNT
DIGITAL POV.1 and ANALOG - The Double Hook & Loop mount with a twist. Get the perpendicular view you?ve been burning to capture. This mount is great for mounting on handle bars, paddles, or anything under a 1 1/2 inch circumference.
GOGGLE MOUNT
DIGITAL POV.1 and ANALOG - Designed to work in conjunction with the universal mount - the goggle mount is a great way to secure your cam with or without a helmet.
ADHESIVE MOUNT
DIGITAL POV.1 and ANALOG - This mount kit provides a lightweight base with adhesive backing and zip ties to secure your helmet cam wherever you need it. This mount is for semi-permanent solutions.
Mount includes 4 adhesive bases and 10 zip ties.
6in FLEX MOUNT
DIGITAL POV.1 and ANALOG - Now you can get the shots that no other mounts would attempt! This flexible steel rod will hold your camera in perfect position for creating exceptional angles. Our flex mounts have a 1/4-20 threaded male connector on one end and a 1/4-20 threaded female recepticle on the other.
12in FLEX MOUNT
ULTRA CLAMP
DIGITAL POV.1 and ANALOG - The Ultra Clamp will mount your V.I.O. camera to items 1/8" up to 1 5/8" in diameter, such as a car window or bike seat post. It works great in conjunction with our flex mounts or as a stand alone mount to catch that tricky angle.
VAC SUCTION MNT
DIGITAL POV.1 and ANALOG - Safely secure your V.I.O. cam to any smooth surface - including your car, boat, jump ramp or bald head. The ball & socket mount allows you to angle your cam in most any direction. It has a 1/4-20 thread bolt to hold your cam and can hold up to 6 lbs. Suction base is 3.75" in diameter.
HEADSTRAP MOUNT
DIGITAL POV.1 and ANALOG - A helmet cam without the helmet! When you find yourself in a position without your trusty brain bucket, don't fret -- this headstrap can be used most anywhere. -Not compatible with our Adventure Cam H2O.
<< Previous Next >>
Back to the V.I.O. Sport booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2009 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
