Home | Reviews
Login  |  Register
Interbike 2007
P.O.V.1 Integrated POV Video System
The POV.1 records in 2 modes, LOOP or CLIP. In LOOP mode, the user TAGs and saves key video segments. In CLIP mode, video is continuously recorded as in traditional video recording. Recording, playback and set-up are controlled by buttons on the POV.1 Recorder.
Video:
Frame rates: 30fps, 25fps, 24fps, 15fps Resolutions: 720x480, 720x400, 640x480, 360x240 Formats: MPEG4 AVI (DivX Codec) digital, NTSC/PAL analog Exposure control: Automatic exposure control and white balance
Imaging Hardware:
Sensor: Advanced CMOS sensor with electronic global shutter Dynamic range: 75dB to 110dB Sensitivity: 5 lux color sensor (Sub 0.1 lux monochrome sensor) Processor: 32 Bit MIPS processor, 12 Bit image
Optics:
Sensitivity: F2.0, relative illumination @ full field 74% Effective focal length: 4.5mm
Audio:
Mic type: Monaural Omni directional cable-mounted, -40dB sensitivity at 1kHz Resolution: 16-bit half duplex Sampling rate: 32kHz SNR: 80dB Speaker: Monaural 8ohm mylar, 0.7W Max
Input/Output:
Recording capacity: Includes 1GB SD card, 2GB SD card capability I/O Ports: SD card slot, USB 2.0 high speed (Mini -B), Mic-In, NTSC/PAL Analog TV/Audio Out
<< Previous Next >>
Back to the V.I.O. Sport booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2009 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
