Click Here for Coverage of Interbike 2008!
Home | Reviews
Login  |  Register
Interbike 2007
Moflow OEM (Oakley)
The MOFLOW (more flow) system has drastically improved your outdoor drinking experience. Say goodbye to the days of having to “suck” from a hose. This revolutionary system comes with an air pump and is made with 100% antimicrobial film and hardware by Microban®. Simply inflate before your activity and "Go with the Flow". The MOFLOW is more than just a drinking system and the uses are endless. Whether hiking, biking, camping, running with mans best friend or cooling yourself on a hot day, you will always find a good use for the MOFLOW reservoir. When camping, the MOFLOW is also ideal for washing up, cleaning your gear, and can even be used as a backcountry shower and pillow. The uses are endless!
Tests have proven that you drink up to 30% more water when using the MOFLOW system. The two internal baffles also prevent your liquids from "sloshing" when in motion. Do yourself a favor and go with the flow. You will not be disappointed!
  • 70oz fluid capacity
  • 100% antimicrobial (reservoir, hose, couplers, bite valve and screw cap)
  • Two quick release couplers with shut off valve
  • 360 degree rotation, 90 degree angle MOFLOW bite valve
  • Pump system
  • No slosh baffles
  • Drink more water
    * Note: The reservoir is co-branded with the Oakley and Polarpak logo’s.
  • << Previous Next >>
    Back to the Polarpak booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
