• Externally adjustable compression damping
• Externally adjustable rebound damping
• 12mm oversized shock shaft
• Multi-Circuit damping
• Adjustable spring pre-load
• Adjustable bottom-out air-pressure
• New forging style body cap
• Newly designed rebound knob
Designed for downhill and extreme-freeride and redesigned for professionals by professionals. The X-Fusion Vector DH series coil shocks are serious suspension for extreme and aggressive riding. The all-new reinforced body cap gives the new X-Fusion Vector DH2 lighter construction with a more fluent oil circuit design. This design greatly improves high and low speed bump performance as well as significantly increasing the field life of the shock.
New for 2007 the Vector DH2 comes standard with a Titanium spring for significant weight savings.
An 8.75 x 2.7 Vector DH2 weighs in at 752g making it one of the lightest on the market. The Vector DH1 and Vector DH2 have all of the features one needs to conquer the downhill terrain. The factory tuned precision shim stacks and external compression and rebound adjustments give the rider all necessary features to set the bike to a perfect ride. The Vector DH is the ultimate downhill and freeride shock on the market today. |
