Home | Reviews
Login  |  Register
Interbike 2007
02 RL
• Firmness control (US PAT. 6279703)
• Externally adjustable rebound damping
• More linear air spring
• Multi-Circuit damping
• Nitrogen Charged IFP
• Infinitely adjustable air spring
• Newly designed decals
• Remote control version available
• RLS* compatible
• Weight: 249g
The X-Fusion O2 RL is a unique design that incorporates two separate adjustments into one easy to use lever. Compression and rebound are both adjusted using the same lever. In the open position, both rebound and compression are minimized. Rotate the lever counter-clockwise to increase rebound and compression at the same time until the lever stops and compression lock-out is achieved. Don’t worry, there is a blow-off in case you forget to unlock. The O2 RL is the ideal shock and offers mega - performance for the advanced rider who likes to keep it simple.
<< Previous
Back to the X-Fusion booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
