| Model: DH200
Speeds: 9 Speed
Frame: 6061, 8.5 travel with 4 bar Horst bearing linkage & ISCG mount
Rear Shock: FOX DHX 5.0, Pro Pedal, rebound adj & Bottom out resistance
Fork: FOX 40RC2, 203mm, Extrnl Adj: rebound, preload and low & hi spd adj. Intrnl Adj: Trvl adj and bottom out damper.
Headset: Cane Creek PIG, 1 1/8 Threadless
Rims: Sun Ringle Single Track, Welded
Hubs: Formula Disc, Sealed Bearing, 20mm through axle ft, Cassette 12mm x 150mm rr
Tires: John Tomac Nevegal 26x2.5 ft/2.35 rr, kevlar bead
Spokes: 14G stainless steel, black, 32°
Derailleur, Front: N/A
Derailleur, Rear: Shimano Saint
Shifters: SRAM Attack Trigger
Chain: KMC Z9000
Crankset: TruVativ Holzfeller OCT Open Core, 170mm x 40T
BB: TruVativ Howitzer splined outboard cartridge bearing
Freewheel-Cassette: SRAM PG950 11-26, 9-Speed
Pedals: Alloy platform w/replacable pins
Seatpost: TruVativ XR
Saddle: WTB Rocket V Comp
Handlebar: TruVativ Holzfeller , 31.8mm, Trpl Btd
Stem: TruVativ Holzfeller, 31.8mm x 60mm
Grips: PowerTools dual density
Brake Levers: Hayes Stroker Trail
Brakes: Hayes Stroker Trail 8 rotors
Color: Flat Black
Frame Size: S, M
