Home | Reviews
Login  |  Register
Interbike 2007
frame detail
Pivot uses a 92mm press-in XTR bottom bracket it developed with Shimano. It lightens the frame by about 100 grams, while making for a wider, stiffer perch for the downtube and bb/pivot assembly. Pivot also uses a bolt-on front derailleur to make room for its optimized pivot. The added benefit is that the chainline is perfect every time and shifting is more precise.
<< Previous Next >>
Back to the Pivot Cycles booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
