Home | Reviews
Login  |  Register
Interbike 2007
New Blitz II Frame
Of course there is the venerable Blitz II: The frame that put us on the map. Pictured here is the 2007 version (which by the way just won the MTBR “best of” award in the freeride category). For 2008 we will make a couple of improvements to the frame:
The 2008 Blitz II will retain its comfortable and flickable geometry that made it famous. Although the new Blitz II still boasts all needle bearings (externally greaseable), the main pivot will incorporated 4 thrust washers instead of 2 which improves the wear resistance of the washers so the thrust loads are being handled by two washers instead of one at any given time. Also we’ve redesigned the rocker link to make it lighter and incorporated a new anodized finish. The 2008 Blitz II will also have a 1.5 head tube and overall will be 1 lb lighter.
  • High Strength, 7005-T6, Versatile 170mm Travel Frame, ISCG-05
  • Needle Bearings At All Pivots With External Grease Ports
  • All-Custom CNC’d Frame parts
  • Extremely Laterally Stiff Rear Suspension
  • All Shock Options Available
  • Engineered in the USA
    New for 2008 Blitz II (07 Blitz II Pictured)
  • Lowered Standover on L and XL frames
  • 1.5 Headtube
  • Revised CNC components, with revised rocker links
  • Reduced frame weight by 1 lb
  • Quad Thrust Washers on Main Pivot
  • Next >>
    Back to the Versus Cycles booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2009 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
