Syncros Bulk Series Handlebars
SYNCROS HANDLEBARS
Custom Design by width, sweep angle, materials and butting
Each bar is custom drawn and butted to maximize the characteristics of the materials
Available oversize 31.8mm
Sweep angles of all Syncros bars are individually customized according to width. This helps maximize the clamping area for grips, shifters and brake levers and provides maximum handling and long ride comfort.
7075 Syncros bars have a dual finish. A polished grip area prevents slipping of hand grips while the bead blasted center section maximizes surface strength and fatigue resistance
BULK 7075 | BULK 2014
Intended use: Heavy duty freeride / DH use
Material: double butted 7075 (265g) or 2014 (315g)
Rise: low (20mm) and mid (40mm)
Width: 690mm
Sweep: 9 degree
Clamp size: OS (31.8mm)
Available in BB black or matte white finish
BULK CARBON
Intended use: All Mountain / Enduro
Material: carbon fiber composite
Rise: low (20mm x 690mm)
Width: 690mm
Sweep: 9 degree
Lightweight: 190g (690mm)
