Home | Reviews
Login  |  Register
Interbike 2007
Syncros Gain Series Handlebars
SYNCROS HANDLEBARS
  • Custom Design by width, sweep angle, materials and butting
  • Each bar is custom drawn and butted to maximize the characteristics of the materials
  • Available oversize 31.8mm
  • Sweep angles of all Syncros bars are individually customized according to width. This helps maximize the clamping area for grips, shifters and brake levers and provides maximum handling and long ride comfort.
  • 7075 Syncros bars have a dual finish. A polished grip area prevents slipping of hand grips while the bead blasted center section maximizes surface strength and fatigue resistance
    GAIN 7075 | GAIN 2014
  • Intended use: All Mtn / Hardcore XC
  • Material: double butted 7075 (240g) or 2014 (310g)
  • Rise: Low (25mm) and Mid (40mm)
  • Widths: 630mm / 660mm
  • Sweep: 9 degree (40mm rise) or 5 degree (25mm rise)
  • Clamp size: OS (31.8mm)
  • Available in black and matte white finish
    GAIN CARBON
  • Material: carbon fiber composite
  • Rise: low (25mm)
  • Width: 640mm
  • Sweep: 9 degree
  • Lightweight: 180g
  • << Previous
    Back to the Ritchey booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
