Swinger Coil X6
Type: Coil
Weight (g): 448
Damping: Intrinsic or SPV
Package: 2007 Intrinsic Piggyback
Adjustments: Preload, Rebound, No Tools, Volume, LS Comp, HS Comp
Damper Body Finish: Black Hard Ano
Damper shaft material: Steel
Damper shaft finish: Hard Chrome
Eyelet hardware: 2-pc AL through 37.9mm, 3-pc S.S. at 38mm and wider
Shaft Diameter: 12.7mm
Springs: Steel, 250 to 650 Springs in 50lb increments
Configurations
190 x 50 (7.5" x 2")
200 x 50 (7.875" x 2")
200 x 56 (7.875" x 2.25")
216 x 63 (8.5" x 2.5")
222 x 70 (8.75" x 2.75") 500lb. spring max
230 x 70 (9" x 2.75")
240 x 76 (9.5" x 3")
267 x 90 (10.5" x 3.5")
All shock weights in smallest configuration.
