Revox ISX
Type: Coil
Weight (g): 465 (without spring)
Damping: Intrinsic
Package: Intrinsic Piggyback
Adjustments: Preload, No Tools Volume, Rebound, LS Comp, HS Comp
Damper Body Finish: Black Hard Ano
Damper shaft material: Aluminum
Damper shaft finish: Natural Hard Ano
Eyelet hardware: 2-pc AL through 37.9mm, 3-pc S.S. at 38mm and wider
Shaft Diameter: 14mm
Springs: Steel
300 to 450 70mm (2.75") travel
300 to 550 76mm (3") travel
250 to 450 90mm (3.5") travel
Configurations
222 x 70 (8.75" x 2.75") 500lb. spring max
230 x 70 (9" x 2.75")
240 x 76 (9.5" x 3")
267 x 90 (10.5" x 3.5")
All shock weights in smallest configuration and without spring.
