Home | Reviews
Login  |  Register
Interbike 2007
Evolver ISX-6
Evolver ISX-6
  • Type: Air
  • Weight (g) : 415 (single tube) 470 (twin tube)
  • Damping: Shims-Intrinsic
  • Package: New piggyback reservoir
  • Adjustments: Air, No Tools Volume, Rebound, HS Comp, LS Comp
  • Damper Body Finish: Black Hard Ano
  • Damper shaft material: Aluminum
  • Damper shaft finish: Hard Ano
  • Negative spring: MCU
  • Air canister: 40/49 3D Forged Twin Tube
  • Top Cap: New Style Bell Shape
  • Eyelet hardware: 2-pc AL through 37.9mm, 3-pc S.S. at 38mm and wider
  • Shaft Diameter: 12mm
    Configurations
  • 190 x 50 (7.5" x 2")
  • 200 x 50 (7.875" x 2")
  • 200 x 56 (7.875" x 2.25")
  • 216 x 63 (8.5" x 2.5")
  • 222 x 70 (8.75" x 2.75")
  • 230 x 70 (9" x 2.75")
  • 240 x 76 (9.5" x 3")
    All shock weights in smallest configuration.
  • << Previous Next >>
    Back to the Manitou-Answer booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
