Home | Reviews
Login  |  Register
Interbike 2007
R7 Carbon
R7 MRD TPC
  • Category: Ultra Lightweight High-End 30mm
  • Travel: 80mm or 100mm
  • Wt. Lbs: 2.76 (80), 2.8 (100)
  • Wt. Grams: 1253 (80), 1271 (100)
  • Spring: Noble Air
  • Steerer: Butted Aluminum
  • Damping: Lightweight Cartridge TPC
  • Adjustments: Air, Rebound, Compression
  • Stanchions: 30mm Gold Al
  • Casting: One piece Reverse Arch (RA) Magnesium
  • Axle: Std
  • Crown: Deep Bore Hollow MRD
  • Lubrication: Semi-Bath with Evil Genius Seals
  • Wheel Size: 26
  • Disc Mounts: Post
  • Disc Size: 180mm Max
  • No Boss Only:
  • Ride Height (mm) : 456/476
  • Color: Candy Red
    Compatible Rear Shock Models
    S-Type, S-Type MRD
  • << Previous Next >>
    Back to the Manitou-Answer booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
