Minute MRD TPC
Category: High End Al 32mm
Travel: 100mm or 130mm
Wt. Lbs: 3.2 (100), 3.3 (130)
Wt. Grams: 1452 (100), 1530 (130),
Spring: Noble Air
Steerer: Aluminum
Damping: Lightweight Cartridge TPC
Adjustments: Air, Rebound, Compression
Stanchions: 32mm Gold Al
Casting: One piece Reverse Arch (RA) Magnesium
Axle: Std or Hex
Crown: Aluminum
Crown Spec: Deep Bore Hollow MRD
Lubrication: Semi Bath with Evil Genius Seals
Wheel Size: 26
Disc Mounts: Post
Disc Size: 210 Max
No Boss Option: Only
Ride Height (mm) : 478/508
Color: Grayblue
Compatible Rear Shock Models
Swinger Air X3, Swinger Air X4
