Home | Reviews
Login  |  Register
Interbike 2007
Gold Label
Gold Label Jump series 2
  • Category: High End 32mm Street and Dirt Jumping
  • Travel: 80mm or 100mm
  • Wt. Lbs: 4.6
  • Wt. Grams: 2086.1
  • Spring: X-Firm Coil Spring
  • Steerer: 1 1/8th High-strength steel
  • Damping: FFD with rebound adjust
  • Adjustments: Rebound
  • Stanchions: 32mm Gold Al
  • Casting: One piece Reverse Arch (RA) Magnesium
  • Axle: 20mm Hex Lock Thru Axle
  • Crown: Hollow Aluminum
  • Lubrication: Semi Bath with Evil Genius Seals
  • Wheel Size: 26
  • Disc Mounts: Post
  • Disc Size Size: 210 Max
  • No Boss Option: Only
  • Ride Height (mm) : 460, 480
  • Color: Disco Gold
  • Notes: Grind bolt on spring leg
    Compatible Rear Shock Models
    Swinger Air X3, Swinger Air X4
  • << Previous Next >>
    Back to the Manitou-Answer booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
