Travis single 150
Category: 34mm Freeride/DH Racing
Travel: 150mm
Wt. Lbs: 6.5
Wt. Grams: 2947.8
Spring: Steel Coil
Steerer: 1 1/8th Steel
Damping: Al Cartridge TPC+
Adjustments: Rebound, Compression
Stanchions: 34mm Gold Al
Casting: One piece Reverse Arch (RA) Magnesium
Axle: 20mm Hex Lock Thru Axle
Crown: Solid Satin Black Aluminum
Lubrication: Semi Bath with Evil Genius Seals
Wheel Size: 26
Disc Mounts: Post
Disc Size: 210 Max/ 203 Min
No Boss Option: Only
Ride Height: (mm)542
Color: Primer
Compatible Rear Shock Models
Swinger Coil, Revox, Evolver
