Home | Reviews
Login  |  Register
Interbike 2007
Travis Triple
Travis triple 180 intrinsic | 203 intrinsic
  • Category: 34mm Freeride/DH Racing
  • Travel: 180mm or 203mm
  • Wt. Lbs: 7.8, 7.9
  • Wt. Grams: 3521, 3557
  • Spring: Steel Coil
  • Steerer: 1 1/8th Black Al
  • Damping: Cartridge Air Backed IFP Intrinsic
  • Adjustments: Rebound, Compression, Cartridge Air
  • Stanchions: 34mm Gold Al
  • Casting: One piece Reverse Arch (RA) Magnesium
  • Axle: 20mm Hex Lock Thru Axle
  • Crown: Integrated Triple Clamp
  • Lubrication: Semi Bath with Evil Genius Seals
  • Wheel Size: 26
  • Disc Mounts: Post
  • Disc Size: 210 Max/ 203 Min
  • No Boss Option: Only
  • Ride Height (mm) : 562/ 585
  • Color: Primer or Grandma's Lipstick
  • Included Parts: Triple Clamp/Small, Large, Soft & Hard Springs
    Compatible Rear Shock Models
    Swinger Coil, Revox, Evolver
  • << Previous Next >>
    Back to the Manitou-Answer booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
