Home | Reviews
Login  |  Register
Interbike 2007
MeGa
THE MEGA: DH & FR
Master Cylinder (Lever)
  • Forged lever blade with engineered braking point: In the event of a crash the lever blade will fail at a location which still allows the rider to use the remaining portion for braking. One or two finger compatible.
  • Linkage driven Pushrod. 2 pcs lever linkage maintains contact point through reach adjust changes and facilitates direct compression of MC piston.
  • Alloy FCS knob allows for changes in lever contact point.
  • Ultra high volume reservoir virtually eliminates pump up, even on the longest and steepest descents.
  • Reach adjust with 3mm hex.
  • Positioning compatibility with available shifters on market.
  • Graduated power band resists on/off feel.
  • Direct exit hose with reattachable fitting.
    Caliper:
  • HUGE 24mm Caliper Pistons for amazing power.
  • Pressure cast 2 piece caliper.
  • Offset caliper halves reduce weight and improve visual appearance.
  • Post mount caliper allows compatibility with all current frame and fork standards.
  • Top Vented caliper allows for wheel on pad changes.
  • Bottom vented caliper pistons eliminate brake fade!
  • << Previous Next >>
    Back to the Formula booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
