The Oro Line: XC/AM/Light DH
ORO PURO: XC SL
Master Cylinder
Compression molded carbon fiber lever blade is 2x as strong as hand laid version and passes all the same tests as our alloy lever blades.
Patented Feeling Control System (FCS) which changes the lever contact point!
Kevlar braided hose for ultimate expansion resistance.
Titanium and Alloy fasteners. (lever clamp screws, hose crimps, banjo bolt)
Flip-flop lever design with removable clamp.
Patented inline open system reservoir which makes for a super compact lever design.
High capacity reservoir for better fade resistance.
Caliper
Titanium and alloy fasteners:
Alloy backed brake pads for weight savings.
Post mount style calipers w/adaptors. No shims = quick adjustments.
22mm pistons for the most stopping power of any 2 piston XC brake (Lab Tested by Bike Magazine - Germany).
Quick and easy pad replacement without wheel removal.
Vented Caliper for increased heat dissipation.
Upgraded features over Oro Bianco/Oro K24:
Carbon lever blade.
Kevlar woven hose.
Ti and Alloy Fasteners throughout.
Alloy backing plates on pads.
