Oro K24: XC RACE
Master Cylinder (Lever)
Patented Feeling Control System (FCS) changes the lever contact point!
Polyester braided hose for increased expansion resistance.
Nickel plated fasteners for increased corrosion resistance.
Flip-flop lever design with removable clamp.
Patented inline open system reservoir which makes for a super compact lever design.
High capacity reservoir for better fade resistance
Caliper
Semi-Metallic pad compound for increased modulation and noise reduction.
Post mount style calipers w/adaptors. No little shims to mess with = quick adjustments.
22mm pistons for the most stopping power of any 2 piston xc brake (Lab Tested by Bike Magazine - Germany).
Quick and easy pad replacement without wheel removal
Vented Caliper for increased heat dissipation.
Upgraded features over K18:
FCS Adjuster
