Home | Reviews
Login  |  Register
Interbike 2007
SRAM Red Crankset
Putting the power to the pavement: the stiff, smooth, and strong SRAM Red Crankset is poised to dominate.
Fatigue, flex, and friction, enemies all, and they'll rob you of speed and performance over both th short and long hauls. The SRAM Red Crankset does its part to keep them from affecting your ride. The integrated carbon spider's design is lightweight and extremely stiff, allowing for instant, efficient power transfer.
Speed-sapping friction? The Red Crankset virtually eliminates it with new hybrid ceramic bearings housed within the GXP BB's case. Ceramic bearings ride in a stainless steel race, are more efficient, use a lighter seal, and are lighter, stiffer, and longer-lasting than normal bearings.
  • Arm Material: Carbon
  • Chainring Material: AL 7075-T6 Aluminum/Alloy Chainring Bolts
  • Weight: 760g w/BB
  • Available Arm Lengths: 165, 170, 172.5, 175, 177.5, 180mm
  • Available Ratios: 53/39 and compact drives 50/36 and 50/34
  • Compatibility: GXP Team BB w/ BlackBox Ceramic Bearings
  • Next >>
    Back to the SRAM booth
    Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
     MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
     PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
     AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
    Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
