We took the standard cassette and turned it inside out!
There are times when the simplest solution is the best one. In the case of the new OG 1090 Cassette, simplicity also means elegance, efficiency, and performance. We took up the challenge of re-engineering the cassette from a component made up of many parts down to stripped-down but exceptionally strong set of cogs that stick firmly to SRAM Red's cor principlees of light weight, higher efficiency, and maximized technologies.
Speeds: 10
Weight: 160g
Recommended Chain: PC 1090R, PC 1090, PC 1070
Sprockets on Spider: 3
Lock Ring Material: Aluminum Anodized
Sprocket Material: Heat-treated Steel
Cogs: 26 T, 23T
Available In: 11, 12, 13, 14, 15, 16, 17, 19, 21, 23, 26 |
