Home | Reviews
Login  |  Register
Interbike 2007
32 F29 RLC
A MORE EFFICIENT WHEEL DESERVES A MORE EFFICIENT FORK.
New for 2008, the FOX F29 is the answer to your 29 inch wheel dreams. The new F29 chassis is designed specifically for the demands of the tall wheel crowd. Though ultra lightweight, the crown, tapered casting legs, torsionally stiff webbed brace, and patented and evolved for 08 damper contribute to deliver the steering precision and control synonymous with the FOX name.
WEIGHT:
F80: 3.87 lbs (1.76 kg)
F100: 3.87 lbs (1.76 kg)
TRAVEL:
F80: 3.1 inches (80 mm)
F100: 3.9 inches (100 mm)
ADJUSTMENTS:
> Low speed compression
> Lockout force adjust
> Lever actuated lockout
> Air spring pressure
> Rebound
LOWER LEG: Disc Only
SPRING: Air
DAMPER: Open Bath
FORK COLOR: White
AXLE TO CROWN:
F80 = 480.8mm
F100 = 500.8mm
Next >>
Back to the Fox Racing Shox booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
