Home | Reviews
Login  |  Register
Interbike 2007
Sanchez (galvanized finish)
Sanchez
Take it and make it your own. We envisioned it as a whole, but if you want to chop it, or shave it, or slam it, or French it, or Brazilian it, go ahead.
We've replicated the exact look of our previous galvanized finish, but with paint. Quite possibly one of the tightest rides out there. Quite likely one of the cleanest chassis upon which to stamp your own mojo.
Rear hub can be flipped, if you want to run a single-speed freewheel. Frame and fork accept brakes, if you so choose.
Swobo saddle, machined alloy handlebar end caps and dual-density grips are custom, as well as the white rims and white handlebars. Custom forged rear-entry dropouts with threaded adjuster screw, for proper wheel alignment.
We designed the 7 frame sizes with a proportional slope to the top tube. The smallest size, 46cm, has more slope than the largest size, 62cm, which is virtually flat. 46cm and 62cm sizes will be new in October 2007.
<< Previous Next >>
Back to the Swobo booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
