Ritual (dirt-high)
FRAME: Updated Mongoose 4130 CroMoly 26” Jumping w/ Rim Brake Mounts, Disc Brake Mounts, 135mm Hub Spacing, Bolt-On Derailleur Hanger
FORK: Marzocchi Dirt Jumper 2, Coil Spring w/ Air Assist Preload, Rebound Adjust, Thru Axle, 20mm Thru Axle, 100mm Travel
DRIVETRAIN: SRAM X-7 9-Speed Derailleur, SRAM X-5 Shifter, FSA Moto X Crankset w/ 36t Chainring & PC Bashguard, 2-pc Integrated BB
BRAKES: Hayes Stroker Trail Hydraulic Disc, 160mm Rotors
WHEELS: Sun Ditch Witch Rims, Mongoose 20mm Thru Axle F & Bolt On Rear 8/9-Spd Alloy Hubs, Kenda Small Block Eight 2.35” F. & K-Rad 2.3” R. Tires
COCKPIT: Mongoose Pry Bar CroMo 50mm Rise Bar & Alloy BMX Stem, SDG I-Beam Post & SDG I-Sky Saddle
MSRP $1099
