Home | Reviews
Login  |  Register
Interbike 2007
Khyber Elite
With 6.5 inches of rear axle travel and a heavily-fortified monocoque chassis, Khyber screams its intent – this all-mountain Mongoose is ready to kick ass. Named after Whistler’s epic Khyber Pass, the Khyber was designed as an “up/down” bike. With an efficient FreeDrive suspension system and a heavy-duty frame, the Khybers are almost as much fun going up as it is coming back down.
Both Khybers are spec’d with Marzocchi air suspension, SRAM two-ring drivetrains and thru-axle forks.
Khyber Elite
FRAME: New Mongoose FreeDrive All Mountain/Freeride 6061 Aluminum w/ Patented Floating BB, Disc Mount, Adjustable (165mm) Travel
FORK/SHOCK: Marzocchi 55 TST2 w/ Air Spring, 160mm Travel, Rebound, Compression & Preload Adjust, 20mm Tool-Free Thru Axle; Marzocchi ROCO Air R Piggy Back w/ Rebound Adjust
DRIVETRAIN: SRAM X-7 Rear & Shimano Deore Front Derailleurs; SRAM X-7 Trigger Shifters; FSA Moto X 24/36t Crankset w/ Bashguard & External Bearings; MRP Long Range Patrol Dual Ring Chain Keeper
BRAKES: Hayes Stroker Trail Hydraulic Disc w/ 180mm F & 160mm R Rotors
WHEELS: WTB Dual Duty Rims w/ Mongoose 20mm Thru Axle Front & Shimano Rear Disc Hubs, Kenda Nevegal DTC 2.35” Folding Bead Tires
COCKPIT: Funn 31.8mm Riser Bar & Rippa Stem, Mongoose 2014 Alloy Post & WTB Pure V Race Saddle
MSRP $1899
Next >>
Back to the Mongoose booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
