Black Diamond Freeride
Superstar freerider Steve Romaniauk has been aboard a Black Diamond on Rip.TV’s Drop In series. The rear dropouts are now simpler and make for a frame that’s cheaper to repair in case of a derailleur-mangling incident. Marzocchi coil-sprung suspension is found at both ends.
Black Diamond Double
FRAME: Mongoose FreeDrive Extreme 6061 Aluminum w/ Patented Floating BB, 1.5” Headtube, 150mm QR Dropouts & Disc Mount, Adjustable 6.7/7.5” (170/190mm) Travel
FORK/SHOCK: Marzocchi 66 RCV 8 w/ Preload, Compression & Rebound Adjust, 180mm Travel, 20mm Tool-Free Thru-Axle; Marzocchi ROCO R Coilover w/ Piggyback Reservoir, & Rebound Adjust
DRIVETRAIN: SRAM X-7 9-Speed Derailleur, SRAM X-7 Trigger Shifter; FSA Gap 36t Crankset w/ Bashguard & External Bearings; MRP SB3 Chain Guide
BRAKES: Hayes Stroker Trail Hydraulic Disc w/ 203mm Rotors
WHEELS: WTB Speed Disc XL Rims w/ 32h h Thru-Axle Disc Hubs, Kenda Nevegal FR 2.5” Tires w/ Stick-E Rubber & Pinch Flat Protection
COCKPIT: Funn Fatboy 31.8mm Bar & Rippa Stem, Titec Knockscoper I-Beam Telescoping Post & SDG Bel Air ST Saddle
MSRP $1999
Black Diamond Triple
FORK/SHOCK: Marzocchi RC3 1 ATA w/ Air & Coil Spring, 180mm Travel, RC2 Rebound & Compression Adjust, 20mm Tool-Free Thru Axle; Marzocchi ROCO TST R Coilover w/ Piggyback Reservoir, 5-Position Compression & Rebound Adjust
DRIVETRAIN: SRAM X-9 9-Speed Derailleur, SRAM X-9 Trigger Shifter w/ Matchmaker; FSA Gravity 36t Crankset w/ Bashguard & External Bearings; MRP SB3 Chain Guide
BRAKES: Formula K24 Hydraulic Disc w/ 203mm Rotors
WHEELS: WTB Laser Disc FR Rims w/ WTB Laser Disc Super Duty 32h Thru Axle Disc Hubs, Kenda Nevegal FR 2.5” Tires w/ Stick-E Rubber & Pinch Flat Protection
MSRP: $2999
