Home | Reviews
Login  |  Register
Interbike 2007
EC-D
ERIC CARTER DH/4x
Eric Carter’s signature downhill ride is now available in three sizes. We’ve added a longer size to accommodate taller riders. Mongoose’s Andrew Neethling has been aboard the “long” all season. Other changes include a new OnePointFive headtube that lowers the stack height 18mm and additional frame gusseting.
FRAME: Mongoose FreeDrive Downhill 6061 Aluminum w/ Patented Floating BB, 1.5” Headtube, 150 x 12mm Thru-Axle Dropouts & Disc Mount, 7.3-8.4” (189-214mm) Travel
FORK/SHOCK: RockShox Boxxer Team w/ Motion Control Damping w/ High & Low Speed Compression Damping & Rebound Adjust, 203mm Travel; RockShox Vivid 5.1ST Coilover w/ Piggyback Reservoir, External Beginning & Ending Rebound, Low Speed Compression & Drop Stop
DRIVETRAIN: 9-Speed w/ SRAM X-9 Derailleur & Trigger Shifter; Truvativ Holzfeller 38t Crankset w/ External Bearings
BRAKES: Avid Juicy 7 Hydraulic Disc w/ Speed Dial Adjust & 8” Rotors
WHEELS: Sun MTX Team Rims w/ Ringle Jumping Flea & Abbah SOS Thru Axle Disc Hubs, Kenda Nevegal DH 2.5” Tires w/ Stick-E Rubber
COCKPIT: Funn Full-On Bar & RSX Boxxer Direct-Mount Stem; SDG I-Beam 2014 Alloy Post & Bel Air ST Saddle
MSRP $3299
<< Previous Next >>
Back to the Mongoose booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
