Click Here for Coverage of Interbike 2008!
Home | Reviews
Login  |  Register
Interbike 2007
Canaan Team
The Canaan line of endurance XC machines adds the Comp model while all frames have some added frame reinforcements. With 100mm of wheel travel, Canaans make for a perfect ride for the endurance XC rider. All models also have a 69.5 degree head tube for better handling when you’re at hour 22 of a 24 hour race.
Canaan Team
FRAME: Mongoose Butted Aluminum FreeDrive XC Enduro w/ 3.9” (100mm) Travel
FORK/SHOCK: Fox F100RLC, Air Spring, Compression, Threshold & Rebound Adjust, 100mm Travel; Fox RP23 Air Shock w/ Adjustable Rebound & 3-Setting ProPedal
DRIVETRAIN: SRAM X-0 Rear & Shimano XT Front Derailleurs, SRAM X-0 Trigger Shifters w/ Matchmaker Mount; SRAM Noir Team Carbon Cranks w/ External Bearings
BRAKES: Avid Juicy Ultimate Hydraulic Disc, 160mm Rotors
WHEELS: No Tubes ZTR Olympic Disc Tubeless Rims w/ Ringle Dirt Flea Disc Hubs, Kenda Small Block Eight 2.1” DTC Folding Bead Tires
COCKPIT: Easton Monkey Lite SL Lo Rise Handlebar & EA70 Stem, Easton EC70 Carbon Post & WTB Silverado Team Saddle
MSRP $2999
<< Previous Next >>
Back to the Mongoose booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
