Home | Reviews
Login  |  Register
Interbike 2007
Redemption 1
FRAME: Redemption Aggressive All Mountain/Freeride Full Suspension Featuring Equilink, 165mm Travel, 6061 Series DB Aluminum w/Hydroform TT, Oversize DT & ST, Butted Seat/Chainstays, Cold- Yokes and Dropouts, 1.5 Head Tube FORK/SHOCK: RockShox Lyrik 2-Step Air 115mm - 160mm Hollow Crown 35mm Upper tubes, Magnesium Lowers with Maxle 360 20mm axle, External rebound, high speed compression, low speed compression, Floodgate switch and internal Floodgate. Fox DHX Air 5.0, Adjustable Pro Pedal, Bottom Out & Rebound Adjust, Boost Valve DRIVETRAIN: Sram 27 Speed, Sram X-O Rear Derailleur, Sram X-9 Shifters and Front Derailleur. Shimano Deore XT 2pc Crankset with External Bottom Bracket, Shimano Deore XT Cassette, Sram PC-951 Chain. WHEELSET: Easton Havoc Wheelset wi/20mm Front Hub, Maxxis 2.35 Ignitor Tires with Folding Kevlar Bead COMPONENTS: Avid Juicy 7 Brakes 203mm FT/185mm RR Rotors, 1.5 Reducer style Headset, Felt Form Freeride Saddle, Easton Havoc Seatpost, Easton Vice Stem, Easton EA-70 Monkey Bar Handlebar, Felt All Mtn Lock-on Grips
<< Previous Next >>
Back to the Felt Bicycles booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2009 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
