Home | Reviews
Login  |  Register
Interbike 2007
555
The 555 uses "Tube to Tube" technology. So, for this model there are no aluminum or carbon lugs, nor monobloc construction. For the 555, oversized tubes are molded then cut, shaped at the ends in order to be assembled as if they were welded. Welding is replaced by bonding reinforced by carbon strips in order to ensure perfect cohesion of the frame assembly. To optimize frame comfort, our engineers have developed a special geometry for the chain and seat stays. The Comfort Concept chainstays present a center section inversion which is achieved by flattening. This creates an inflection point at the middle of the base and so improves vertical flexibility. At the same time, this shape increases the base horizontally, and improves lateral stiffness. The seat stays are slightly curved in order to encourage the absorption of vibrations and so optimizing comfort.
<< Previous Next >>
Back to the Look booth
Contact Us  •   About Us  •   Terms of Use  •   Privacy Policy  •   Advertising
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
