Great performance, lightweight, and a 44mm offset make this fork the best value in the 29er market! The M-29 has been getting rave reviews in the big wheel world. Check out the MTBR forums and Twentynineinches.com to see for yourself.
Weight: 4 lb 9 oz
Travel: 80mm or 100mm
Color: White or Black
Stanchion size: 32mm
Optional Remote lock-out
Axle to crown height(mm):490/510
MSRP: $329.00
29er Specific
-Built on the same platform as the Titan fork
-The M-29 has a hydraulic system with adjustable compression w/ lock-out and rebound.
-Adjustable air spring.
-Comes with high-pressure air pump.
-Post disc mounts and grease ports for easy maintenance.
